1 - 3 of 3 Posts
Leaking can be prevented by properly doing 24/48 hour leak tests. If you've properly secured all tubing you should not have a leak. You need to run only the pump by grounding the black and green wire on the PSU and let it run for a few days if you're that paranoid that it will leak. I usually only run a 24 hour leak test.
Peace!!!
has @anoob said run a leak test for a couple of days if you still wanna make sure there is no leaks strap on a metal zip-tie n see if it helps
here are a couple of builds with WC setup it will give you a idea about the do's n the don'ts
things which can fit inside the itx case etc etc
http://www.overclock.net/t/1500433/build-log-project-orange-horizon-parvum-systems-s2/0_20
http://www.overclock.net/t/1519171/build-log-finished-parvum-neon-s2-0-watercooled-electroluminescent-build/0_20
here is the official thread for the case it may be of grt help to you too
http://www.overclock.net/t/1501774/official-parvum-systems-owners-club/0_20
help is a helpful video
hope that helped
1 - 3 of 3 Posts
