What is the best way to work with allready installed meshes on cases (the ones on the sides of Node 304 so you know what i am talking about)?
These meshes are pretty hard and if i bend it the wrong way, im guessing there is no straightening it back again to do another bend without the first one being noticable.
Maybe there is a similar mesh (in terms of hole density and size) that can be bught which is more flexible for finger bending? If i use the pliers on the original one i will scratch it.
I need a circular shape, but not just cut circular, it has to have a 5mm lip (like the lid of a jar it should be formed)....
Ideas?
Ideas?
