Custom Water Block; Will it Leak?!
1617 11
HUZZAH!
No leaks! against >90% doubt
Lets freeze some stuff!
Original first post:
Following on from my past thread where I made this waterblock:
I'm about to get things rolling and test it again, this is a first crude effort at a top before I had my new perspex:
The question now is, will it leak?
I think probably...
Will it leak?
  • No
    Votes: 1 6.7%
  • Not much
    Votes: 0 0.0%
  • Badly
    Votes: 12 80.0%
  • It wont contain any water at all
    Votes: 2 13.3%
1 - 12 of 12 Posts
Due to your screw positions it might.
The most likely place a leak will occur is where your thumb is or on the other side.
What did you use to create it? Was it hand made with a dremel?
(sorry i missed the other thread)
Argh, you were right, going to drill some more holes in it and try to get more even pressure over the perspex.
Edit: and yes it was created with a dremel
This is what they make CNC machines for
Discussion Starter · #9 ·
Originally Posted by Glancey;14211758
Hahahaha, major props. Best custom block ever.
Have you leak tested the new Revision 2 yet?
Yup... nicht gut!
The seal has stopped leaking, but themultiple layers of plastic have started leaking
Back to the drawing board with the top design...
I'll make it from 10mm acrylic this time.
1 - 12 of 12 Posts
