Hi to all,
I have made a custom waterloop here is the schematic :
2 Radiators
- XSPC 360 with bitfenix spectre pro led in push
- Alphacool 240 neXxos monsta with Phobya G-Silent 12 2000rpm Black Silent Edition in push
Waterblocks
-EK 780 + EK backplate
-Phobya UC-1EXTREME
Tubing
- XSPC 16/10 mm 3/8 ID 5/8 OD
Pump
- Swiftech MCP350 with EK top
Reservoir
-Phobya balancer 250
FIttings
QDC3 fittings for GPU, EK compression fittings dor CPU, XSPC 4 way fitting and other barbed fittings
My system is this:
Gigabyte z87x-ud5h
i7-4770k OC 4.2GHz @ 1.285v
EVGA Gtx 780 classified
2x8GB Crucial Ballistix Tactical Tracer blt8g3d1608dt2txrg
Samsung 840 EVO 250GB
easonic 760w platinum
The problem is high temperature! I use Gpu-z and realtemp TI
At Idle i have
GPU 48°C
-VRM 46°C
CPU 33°C
At Full
- OCCT Linpack AVX 82°C
- AIDA64 stress test 69C°
AIDA64 stress test or EVGA Precision X test over 95°C! but VRM remains a 58°C What?Why?
I have mounted 4 times gpu WB so i think thermal paste stamp is ok
the liquid temperature is about 30°C
Whats the problem?
thank you in advance for your help
2 Radiators
Waterblocks
-Phobya UC-1EXTREME
Tubing
Pump
Reservoir
FIttings
My system is this:
Gigabyte z87x-ud5h
At Idle i have
GPU 48°C
-VRM 46°C
CPU 33°C
At Full
Whats the problem?
