IF its thin.. an X-Acto Knife may work. You didnt specify the thickness, but if its under .25in, then a razor should work. All you have to do, is score it a few times(8or so) per side, then place it along a straight flat corner of a table, and snap.. It works... It will be slightly rough, but that can always be sanded down(or melted)
