Cutting tool
385 5
I have this case here.
http://www.atxpowersupplies.com/atx-...rix-silver.htm
It has this big cut out metal design on the side, that I think sucks. I'd much rather have just a big clear window. I can remove the acrylic to get at the metal and I want to cut off the design, making simple right angle corners. The metal is only about 1mm thick. What's the best thing to cut with? Tin snips and a file?
1 - 6 of 6 Posts
I actually edited my post since it looked like there wasn't a large amount to cut...go to Lowe's or Home Depot and look for an attatchment...also you might want to look at using scissors to cut it away (if it can cut it) then use the Dremel to shave/sand down the cut aluminum spots, just take off the plxi-glass before you do everything
1 - 6 of 6 Posts
