Mother of...(Implying the epic deal you get)
Source
Codemasters has revealed it's to partner with GameStop in the US to release a mental Limited Edition bundle for DiRT 3. The $300 package (yes, $300) will feature the game as well as a a MODEL 7309: Ken Block Gymkhana Fiesta RC Car. ... |
Includes MODEL 7309: Ken Block Gymkhana Fiesta, Fully assembled, Ready-To-Race, with TQ 2.4GHz High Output radio system with Traxxas Link, Velineon 380 motor, VXL-3m ESC, 7.2 volt NiMH battery & charger, and ProGraphix painted body. Officially licensed Ford Fiesta body design and Ken Block/Monster Energy graphics Officially licensed Volk Racing TE37 wheels (1.9" diameter, 12mm hex) Unique green pushrods and toe links, exclusive to the Ken Block Gymkhana Fiesta Pre-glued, low-profile Gymkhana-compound slick tires molded in a pecially formulated rubber compund for authentic Gymkhana performance and handling Impact absorbing foam front bumper Adjustable height body mounts TQ 2.4GHz High Output transmitter with Traxxas Link -Automatically stores and loads settings for up to 20 Traxxas Link-enabled models - just switch on and drive, "model selection" is not required. -Multi-Function knob -Adjustable steering and throttle percentage (dual rates) -Adjustable steering and throttle sensitivity (exponential) -Adjustable steering and throttle end points -High 13ms frame rate and near-zero latency for responsive control -5-channel micro receiver with dual channel-1 inputs Race-winning, F1-inspired Revo suspension technology and E-Revo integrated chassis design, perfectly optimized for 1/16 scale Powered by the Velineon Brushless Power System Traxxas High-Current Connector allows high-capacity battery packs to deliver maximum voltage to the Velineon Brushless Power System Velineon VXL-3m Electronic Speed Control |
Source
