1 - 8 of 8 Posts
Hi all,
I was looking how to heat an electrolyte in order to study a sample with a microscope and I found about the Peltier modules. My problem is that I need an specific Peltier module. It has to be cylindrical.
Have anybody seen something like that? I have been surfing and trying to gather information, but I could not find a supplier.
I am open to suggestions.
Overclock Failed...
Sounds to me like a Peltier is kind of a backhanded way to heat something. You have to cool something to make heat. Peltiers are designed for cooling. You add energy (electricity) and they get cold. The heat is just a byproduct.that you have to deal with.
What not just a heater? How hot, maybe you know how many watts you need?
A round heater would be much easier to locate that a round pelt.
How about one of those coffee cup coaster style heaters? Maybe on a rheostat to control the temp?
Reactions: toolmaker03
how about just doing it like it has been done for decades... wind a spool around object, add electricity.. spool gets hot... this is how a toaster, a watercooker, almost any heating element works
Or, if you want to be more fancy and play with magnetic fields... try induction heating, then you can set ice aflame
you won't find an off the shelf cylindrical peltier, but you can improvise by machining a cube of aluminium with a cylindrical hole in the center, attach 4 standard tecs to the 4 flat faces of the cube with the cold sides facing in and attach a heatsink to the hotside of the tecs and use screws into the alu cube to clamp down, try to thermally isolate the screws from the heatsink.
EDITED: to remove ideas re heating the cube as OP wants to cool the inside face.
Originally Posted by fego View Post
I'm looking for a cylindrical Peltier where the outside gets hot and the inside cool.
Does it exist?
You could make an arrangement where four long rectangular elements form a square, the inside is in contact with a conductive tube and the outside is in contact with a machined piece with the cube being on the faces adjacent to the peltier elements and the outside being cylindrical... But that will be quite a thing to get machined, and not cheap.
Arrangement such as:
Center orange piece is the square with a circular center bore to be machined, outer orange piece is the tube with a square center bore to fit the outside of the peltiers.
All in all, not cheap to make and you're probably better off with a traditional heater unless you do need the cool bit to be down the center for some reason.
maybe wrap some nichrome wires around it and run a small current over the wires.
its basically the stuff inside heater elements
1 - 8 of 8 Posts
