The Fuzion uses flat rubber seals instead of o-rings. These seals are a product
of injection molding, unfortunately, not all molding slag is removed prior to WB
assembly. The bottom plate seal isn't critical since it is not exposed to water.
However, the inner side of the top seal is completely exposed to water flow.
So, if you plan to purchase a D-Tek, I would suggest you dissasemble it and
remove the slag before installation.
Unless you want this crap in your pumps impeller:
