1 - 4 of 4 Posts
It solely depends on your noise tolerance
I'd get the 140mm fan.
For your hardware you dont need very a ridiculous amount of airflow. My components are more than twice as hot as yours and i use fans with half the speed.
Yate Loon D12SH-12 are too loud for me, consider the D12SM-12.
D14SM-12 should be fine, rated beter than D12SM-12.
1 - 4 of 4 Posts
