Hi,
I have just bought this pump from ekwb
https://www.ekwb.com/shop/ek-xtop-revo-dual-d5-pwm-serial-incl-pump
The motors are these ones on both sides of https://www.ekwb.com/shop/ek-d5-pwm-motor-12v-dc-pwm-pump-motor
The problem is I found out one of the motors cable (the pwm cable [the blue and green cables]) is not connected to the mainboard inside the pump.
So wanted to ask is it safe to use it or should I try to RMA it, or should I solder it myself (I have never soldered any electronic before though)
The problem is on one side only the other side's pump cable are perfectly fine
