Okay guys I swapped to a d5 recently after always using ddcs. Anyway I got it setup atm on a bench rig and the thing sounds like its spitting rocks. It has plenty of waterflow its connected to the bottom of the reservoir with a 5mm male to male to adapter to the intake. I did not turn it on without the reservoir filled, Its brand new, I tested it the other day with just the reservoir to ensure it worked it did and did. It did not make this noise then.
The board is on top on of the bench, the pump is about level with the bottom of the board. The loop goes from the pump out to the first radiator (bottom) the top of that rad is connected to the top of the other rad, then from the bottom of that rad to the CPU then to gpus and back to reservoir.
Is it normal for a d5 to sound like that when its bleeding?
Edit: more info plus something I just found out.
The Pump is EK D5 X Top, what I just learned is that it doesn't make that noise unless the pump is at full speed, if its right on the 5 or less than it works fine but if it goes even a hair past the 5 it makes this noise
DazMode is saying its air in this video here https://www.youtube.com/watch?v=hGsa8oD1bTw&feature=youtu.be&t=4m42s&ab_channel=DazMode
that is the sound, I guess it is air so that is good.
