1 - 6 of 6 Posts
Due to my own clumsiness, I may have broken the rheostat that the red "switch" on the D5 vario is attached to on the circuit board. It isn't fully broken. I think it's hanging by one solder.
I've verified that the pump still works. I don't have the means to test the rpm at this point. Does anyone know what happens to the pump speed when the rheostat breaks (if it's even broken)? It was set at the speed 2 before I messed up.
I did read somewhere that the basic non vario D5 defaults at roughly 4. I'm curious if anyone else knows.
WaterCooler
Welcome to the club!
Lots of people break that thing. I think I've seen replacement switches at ppcs or one of the other watercooling stores. I broke mine the last time I upgraded things. I was still able to kinda make it work once more to get the speed to 4, but my tubing was all hooked up and I was in the middle of filling the loop so I never got around to trying ti fix mine. If you broke it off while it was at 2 then that's probably where it is now.
Umm, How Bout Noooooo.
Wait wait you broke the dial or you broke the rheostat? PPCs sells the Dial not the rheostat.
Since you said its hanging on by 1 solder I assume the former? That is much different than breaking the plastic dial.
I believe there should be 2 wires soldered to it.
Discussion Starter #5
The rheostat. It still works though. I'm just gonna use it as is.
1 - 6 of 6 Posts
