The reason I ask this is because I dont like how the MCP655 pump you can't change the barbs, whereas the Danger Den DDCPX-PRO can.
The pump rock3ralex sent me, I'm almost positive it's the same as the MCP655-B (since I dont see anything for speed adjustment anywhere). The blue label on it reads "corsair"
edit: I'm thinking I will just keep the pump I have (hopefully it is the MCP655) and I will just use it with my existing setup.
