1 - 9 of 9 Posts
since u wanna keep northwoods under 55, u should get a better hs/f, and maybe a nother case fan for ventilation. that should hel alot....proper cooling should be around 45
Originally Posted by 6600Gt1047
well 1 in the back, 2 in PSU, 1 on side by window, 1 on CPU, 1 on Vid card.
What are your case temps? as a rule of thumb, IMO, your case temps shouldn't run any more than 5-7 degrees higher than your room ambient temps. if they do, you need more air circulating in your case, thats my opinion. My case temps don't go over 7c degrees above my room temp, even at load.
1 - 9 of 9 Posts
