Hey guys, I still use the Thermaltake Big Typhoon VX & it works good when I have the fan on high but its so damn loud.
My temps on load are around 45-50, might hit 55 if Im gaming which is not bad. Is the Dark Night worth getting? Would it lower the temps even more & is it loud? The only thing Im worried about is it not fitting. The Typhoon also has a 120mm fan, so does the Dark Knight, so wouldnt it be around the same temps? Or would the upgrade be worth it.
The cooler I have now blocks the first two slots on my MB, which is fine since I use the back two.
Also, installation wise, is it easy to install? I'm not to good with installing HSF's but I didnt have a problem installing the Big Typhoon.
Thanks 4 the help!
Thanks 4 the help!
