1 - 11 of 11 Posts
here over the course of the next few weeks i will be rebuilding and restyling my sig rig Das geist. its going to be a very long and difficult process that will contain all of the following...
new blue led power and hdd leds
striping of the powder coat on my haf 912 case
flat grey primer exterior base coat
high heat flat black interior base coat
re-tapping all screw holes to 8-32 and 10-24 for that machine shop look
3 layer aircraft grey final coat on exterior
3 layer clear coat on interior
hand painted decals and nose cone style pin-up girls (1940's)
paint all mesh flat aircraft grey
reinstall all mesh and brackets as well as front bezel and top bezel
re-install all components and clean up everything
re-rout all wiring
re-rout all tubing
remount radiator and reservoir
possibly repaint the shroud on my h50 pump im sick of the stupid corsair logo i may just go all black or hammered brass i havent decided yet
first series of photos all paint sanded down and first and second base coats on main case done
picture.php?albumid=4174&pictureid=23646
picture.php?albumid=4174&pictureid=23645
base coat on one side panel
picture.php?albumid=4174&pictureid=23631
main case and grills finished
picture.php?albumid=4174&pictureid=23718
picture.php?albumid=4174&pictureid=23717
picture.php?albumid=4174&pictureid=23716
picture.php?albumid=4174&pictureid=23720
picture.php?albumid=4174&pictureid=23719
fully assembled new screw sizes all tapped and case re-organized
picture.php?albumid=4174&pictureid=23722
picture.php?albumid=4174&pictureid=23721
mounted radiator sideways on the top most 120mm fan port and saw a 4c temp drop
picture.php?albumid=4174&pictureid=23723
started pin up girl finished base coats and basic shading
picture.php?albumid=4174&pictureid=23724
added some highlights and shading and added a custom playing card and some accents
picture.php?albumid=4174&pictureid=24438
picture.php?albumid=4174&pictureid=24437
Originally Posted by Philistine;13057782
Now thats a to do list.
yes it is ive been putting it off for a while now and finally i broke down and decided to do it since me and the lady arent getting along to well right now. so i figure what better time than now to do it and relive some stress and tension and keep from getting angry and saying stuff i may regret later i call it awesome art/metal fabrication/computer mod therapy
Discussion Starter · #9 ·
Originally Posted by LolXDFace
Wow, that PSU looks very Tron-like!
its kind of neat id of rather gotten the Corsair Professional Series HX750W Power supply but at the time it was 160 at frys and i picked up the apevia warlock power at microcenter for 100 flat plus tax. so far so good it has 1 year of good standing running high voltages and overclocks on ram/cpu/gpu/nb and ht.
i cant complain
1 - 11 of 11 Posts
