1 - 18 of 18 Posts
Originally Posted by musicPC
Yes it is. Op, you better go with a dedicated soundcard for better SQ.
If he has the latest Realtek drivers, the Realtek provides better sound (at least according to the specs).
That Soundblaster puts out 24-bit (so does the Realtek) and goes up to 92khz (the Realtek goes up to 192khz). So, according to those specs, there wouldn't really be any difference.
Discussion Starter · #6 ·
I cant get my system to output 192khz i just get silence when I set 192
Discussion Starter · #8 ·
Originally Posted by sLowEnd
Xtreme? Xtreme what?
Creative has numerous "Xtreme" cards.
XtremeAudio (This one is crappy), XtremeMusic, XtremeGamer...etc
Xtreme Audio. So basically is the consensus that at 9600hz im better off going with my realtek onboard?
Specs mean nothing when it comes to onboard audio. It is almost always bad in comparison to a dedicated sound card.
I'm willing to bet the X-FI card will be better even though it is the lower-end XtremeAudio. If you have a little bit of time your best bet is to try both, it shouldn't take long to make a decision. 95% sure the dedicated card will be better.
I have an ASUS P7P55D-E LX with VIA VT1708S 8-Channel High Definition Audio CODEC and a SoundBlaster Xtreme Music. I can't speak for the Realtek but my Xtreme Music was noticeably better than the VIA.
Iconoclast
This is the least relevant spec you could have quoted.
The Xtremeaudio isn't really an X-Fi card. It's a rebranded low end Audigy.
That's why it doesn't even use the same drivers as the other X-Fi cards.
Discussion Starter · #14 ·
well after testing using avatar blu ray I honestly cannot tell the difference...there are too many variables (xfi features crystalizer, virtual surround, bass boost)....it seemed like oneboard sounded clearer but that could be because of the soundblasters enhancements...i just dont know!!
Yes it's because of the enhancements. Digital is digital, the point of using a sound card is if you're using the analog outputs or if your mobo doesn't have digital out and you want to run a digital signal to your receiver. If your mobo already has a digital output, a sound card is pointless. Any "enhancement" you're adding is software based and has nothing to do with the soundcard itself.
Go with the Dedicated sound card. I recently got me a used X-Fi XtremeGamer. I'd been using realtek for years and never knew what I was missing. It's like day and night.
Doesn't matter if it's a low end Audigy, it will still sound better than onboard.
1 - 18 of 18 Posts
