I tried installing DD-WRT on my router as I'm having to reboot it almost every day. I followed every step to a T. However after the final 30/30/30 reboot absolutely nothing had changed. I followed the directions on the wiki page for DD-WRT and my router. What could I have possibly missed?
Read the Peacock Announcement.
Download ftp://dd-wrt.com/others/eko/V24-K26/svn13575/dd-wrt.v24-13575_NEWD-2_K2.6_mini_wrt160nv3.bin. If you wish to experiment with a newer build, you can download the latest firmware from ftp://dd-wrt.com/others/eko/V24-K26/ that has "WRT160Nv3" in the file name. You should read the "build thread" for any build you are considering putting on your router, before flashing a newer build, (as discussed in the peacock announcement).
Ensure you have a physical ethernet connection to your router, and disable your wireless adapter, antivirus/firewall protection, and any software that makes strong use of your network (BitTorrent, Streaming Audio/Video, etc).
Perform a hard 30/30/30 reset.
Navigate to http://192.168.1.1/ in your web browser of choice.
At the Linksys Management Mode screen, do not give the reboot command. You will use this page to upgrade your firmware.
Browse to the firmware you downloaded and click Upload.
Do not touch anything. The page will tell you that the upgrade was successful and the router is now rebooting. Your router may take upwards of a couple minutes to reboot. Watch the lights... once the wireless and power indicators are on steadily for several seconds, your router is fully rebooted and you can click "Continue" in your browser window.
If the DD-WRT password change page displays, your upgrade has been successful, and you must now perform another hard 30/30/30 reset. This time, when you navigate to 192.168.1.1, click "Reboot" and wait for the router to come online again so you can configure it.
