1 - 6 of 6 Posts
So when I setup my router and put DD-WRT on it I was more than likely high and now 3 months later when I'm trying to change some settings I can't for the life of me think of the password. I'm thinking I probably left it as the default password but I don't remember what that is. Can someone please tell me the default name and password dd-wrt uses?
Oh and if I did set a password I don't have a clue what it is so what would I do in that case. Thanks.
l: root
p: admin
Username: root
Password: admin
I think capitals matter. If you cancel the login it will tell you that information
If it doesn't work. You need to do the 30/30/30 reset.
hold the reset button all the time you are doing this. (1 minute 30 seconds)
1. hold for 30 seconds.
2. unplug the router. wait 30 seconds. keep holding the button.
3. re-plug the router. wait another 30 seconds. you can now let go of the button.
4. I usually power cycle after. unplug + replug. Not 100% sure if its needed though.
I've got the same problem and after a half of day, I've found out the reason of errors.
This error happened with firefox browser.
Please using edge, ie, chrome. You can access with root / admin or root / password
1 - 6 of 6 Posts
