1 - 20 of 88 Posts
Hello all,
While reading through the forums, I often see a lack of understanding in how your computer calculates DDR2 memory speeds and what you can do to change it. It is my attempt to explain this in detail, as most people give one line answers and you can't possibly explain this in one sentence.
First, let me say that I don't know what the "accepted" term is for a lot of settings since so many people mix old Intel words (like FSB) with AMD features and likewise mix old AMD terms for DDR and socket 939 with newer, very different DDR2 memory and socket AM2. Also, every motherboard uses a different term adding to the confusion. So let me define the terms I'll be using.
a) reference clock - That number that starts at 200MHz and gets multiplied by the CPU multiplier to give you your "total CPU speed". It's what you increase to overclock your CPU.
b) total CPU speed - the total speed, example: 2200MHz for my X2 4200+ at stock
c) memory setting - i.e. DDR2 800, DDR2 667, DDR2 533, DDR2 400. Get the idea? Many people often call this the divider, but as you'll see that isn't really correct.
Here's the basic principle of your DDR2 memory's speed. It's calculated by taking the total CPU speed and dividing it by some number, the divider. This divider isn't chosen at random, the computer follows strict rules when choosing the divider. If you understand how it chooses it, you can control your overclock. Here's the equation written out:
Memory speed = (total CPU speed)/(divider)
So logic tells you that to adjust the memory's speed, you must adjust the "total CPU speed", the divider, or both! As you'll see, this can get complex for DDR2.
Open this chart in another window, it's VERY valuable and will help you understand what I write below:
LEARN THIS CHART. IT'S YOUR FRIEND.
Adjusting the "total CPU speed":
To do this, you either increase the reference clock from 200MHz to a higher number, change the multiplier, or both. However, what usually happens in overclocking, is you figure out that magical "total CPU speed" that your processor can handle at its default multiplier (which cannot be increased). But at that CPU multiplier, you're stuck with a high divider. People will lower their CPU multiplier to get a lower divider, but as you lower the CPU multiplier, your "total CPU speed" drops. Oh noes! So you jack up the reference clock to acheive the same product. So that's why increasing the reference clock has an indirect effect on increasing the memory's speed. It's really the "total CPU speed" that affects the memory's speed, but to acheive that speed with a lower multiplier you need a higher reference clock.
Adjusting the divider:
Everyone uses archaic terms like set a 1:1 divider. Show me an AM2 motherboard with DDR2 memory that has a CPU:memory ratio option in the BIOS and I'll give you a cookie
. As a noob learning to overclock a couple months ago I was like.... "huh?" everytime I heard someone say that, because I had no idea what they meant. I think when people say that, they're referring to the old 939 days where the reference clock was 200MHz (still is) AND the frequency of the memory was 200MHz (but 400MHz effectively since its DDR, or double data rate memory). So setting your memory to DDR 400 was setting it to operate at 200MHz just like the reference clock, or a 1:1 ratio. Those were the simple days when that's all you had to do. In today's world with DDR2 memory, the 1:1 ratio doesn't have much meaning.
Here's what effects the divider with DDR2 memory and AM2 sockets. The CPU multiplier, and what I call the "memory setting" (i.e. DDR2 800, 667, 533, 400). It's not really accurate to just say set the divider since two factors influence it, so several combinations will yield the same divider.
Let's say we hold one factor constant, the memory setting (put it at DDR2 800). With a CPU multiplier of 10 or below, the divider is 5. A multiplier of 11 or 12 gives a divider of 6. A multiplier of 13 or 14 gives a divider of 7. A multiplier of 15 or 16 gives a divider of 8. See a pattern?
What if we hold the CPU multiplier constant, say 10x. Well, at DDR2 800 you get a divider of 5, DDR2 667 the divider is 6, DDR2 533 the divider is 8, and DDR2 400 the divider is 10. Now if you both change the memory setting AND the multiplier, you can get all sorts of combinations. For example, a CPU multiplier of 12 at DDR2 800 gives a divider of 6, but so does a CPU multiplier of 10 at DDR2 667. You have to consider both factors.
One Last Point:
What confuses people the most is the underclocking of memory caused by DDR2 memory paired with an odd or fractional CPU multiplier. Here's what makes it so difficult: THE DIVIDER MUST BE A WHOLE NUMBER. Why is that a big deal? I'll explain in a minute, but first, the three rules your memory follows:
1) The divider must be a whole number.
2) ("total CPU frequency")/divider cannot exceed 400MHz for DDR2 800, 333MHz for DDR2 667, 267MHz for DDR2 533, or 200MHz for DDR2 400 at the stock reference clock of 200MHz.
3) When choosing a divider, the CPU chooses the smallest number that won't violate rules 1 or 2.
Let's take an easy combination. The X2 4400+ Windsor with a 200MHz reference clock and a 12x multiplier and the memory set to DDR2 800. 200 x 12 = 2400MHz, the stock speed. Remember, with the memory set to DDR2 800, it sets your divider to the SMALLEST whole number that won't be greater than 400MHz. 2400/6 = 400, all rules are met. Why not set the divider to 5? 2400/5 = 480, this violates rule 2. Why not set the divider to 7? Because 6 met conditions 1 and 2, and rule 3 says choose the smallest number that works. Easy enough I hope, and it results in your memory running at what you expect it to, 400MHz (800MHz effective).
Let's make it more complicated. Take the X2 4200+ Windsor with a 200MHz reference clock and an 11x multiplier with the memory set to DDR2 800. 200 x 11 = 2200MHz, the stock speed. Remember, with the memory set to DDR2 800, it sets your divider to the SMALLEST whole number that won't be greater than 400MHz. What happens if we set the divider at 5? 2200/5 = 440MHz. This violates rule 2, so the divider stays at 6. Even though the 4200+ runs at 2200MHz and the 4400+ runs at 2400MHz, they use the same divider. Let's look at what effect this has on the memory's speed. 2200/6 = 366.67MHz (733MHz effective). Woah! Even though you set the memory to DDR2 800, it's being underclocked to DDR2 733. This is because ideally, the divider should be 5.5 (2200/5.5 = 400) but that violates rule 1. This is true for all odd CPU multipliers and DDR2 memory, your memory will be underclocked!
Think about it, only multiples of "total CPU speeds" of 400 work out evenly. i.e. 2000MHz, 2400MHz, 2800MHz, etc. If you have a CPU speed like 1800MHz, 2200MHz, 2600MHz, etc then you can't divide by a whole number and get 400, so your memory is being underclocked.
This means that the even multipliers are advantageous if you have good RAM, as they start your RAM at 400MHz instead of some underclocked value. 10x and 12x are very popular for overclockers with good memory because you can get more from your memory.
Remember though, this divider is chosen based on those three rules when the reference clock is at 200MHz. The divider stays the same as the reference clock is increased. However, as clearly shown above, as the reference clock goes up the "total CPU speed" goes up. So if the divider stays the same, but the "total CPU speed" goes up, then as you raise the reference clock to overclock your CPU you'll be indirectly raising the speed of your memory.
I hope this LENGTHY explanation helps some people. Plz correct me if anything is wrong and feel free to add/clarify anything!
EDIT: I changed "HTT" to the more correct term "reference clock". Please note that many of the responses use the term "HTT" and they are referring to the reference clock.
Read half of it, really interresting, however I think I someone made a FAQ about it before, but it still deserves the REP.
Yea there's some FAQ's on the issue but they didn't make much sense to me when I was starting out, I was hoping this would benefit the people who are new to overclocking by giving more detail, examples, and using more descriptive terms (or at least define the terms) instead of technical ones. I know when I first started learning a few months ago it was very hard to understand all the technical terms, especially since everyone calls things like the HTT, divider, etc something different.
Sticky Time
Love it! I will use this to help and hopefully my ancient math skills will come back to me so I can apply this. Rep for you!
Great great article, i understand more, but i hope i don't understood wrongly haha.
Ok so what's the main purpose of this information and chart? :x is it so that when overclocking, we can get the desired RAM clock speed? And because usually when people OC their system they forget about the divider and their RAM get underclocked? Is it so that when someone overclock their system the CPU speed has to be the right one so that their RAM speed can achieve 400MHz for a DDR2 800 RAM?
I heard people overclock their RAM, so if the rules stated the speed can't be over 400MHz for DDR2 800, how can overclock the RAM possible? Is there a reason why the chart shows speed up to 1000 for multiplier 14, 800/7, CPU FSB 250, that will be 500MHz? So this breaks the rule because it's over 400MHz?
"Let's say we hold one factor constant, the memory setting (put it at DDR2 800). With a CPU multiplier of 10 or below, the divider is 5. A multiplier of 11 or 12 gives a divider of 6. A multiplier of 13 or 14 gives a divider of 7. A multiplier of 15 or 16 gives a divider of 8. See a pattern?"
This part i ...think i might get it... but how does one get the divider for them? why DDR2 667's divider is 6 on multiplier of 10x? Why DDR2 667 divider is 7 if multiplier is 11, etc..
Sorry for the question, this is what students do :x
please bare with me
The purpose is to help people better understand how memory speed is calculated. What you do with the information is up to you, but it should help you get a better overclock
My main motivation was that a lot of people still say things like "set the divider" which was an option in the BIOS in the socket 939 and DDR days, but no longer has the same meaning with socket AM2 and DDR2 memory.
Take another look at rule #2, in bold it says "at the stock HTT of 200MHz". The memory's speed cannot exceed 400MHz for DDR2 800 when the HTT is 200MHz, however if you increase the HTT beyond 200MHz you can increase the speed of the memory beyond 400MHz. It can get confusing I know.
please bare with me
The divider is determined by following rules 1-3 described in my original post. Remember, these rules are used to calculate the memory's speed when the HTT is 200MHz, I think that's the part you're struggling with.
Taking your example of DDR2 667, consider this. At a CPU multiplier of 10x, and the HTT at 200MHz, the total CPU speed is 2000MHz. A divider of 5 gives 400MHz, which violates rule #2 (memory can't run faster than 333MHz at DDR2 667 and an HTT of 200MHz). A divider of 6 gives 333MHz, all rules are satisfied. I divider of 7 gives 286MHz, rules 1 and 2 are satisfied but rule 3 is violated because a divider of 6 works just as well.
If you increase the CPU multiplier to 11x (and hold the HTT at 200MHz), the total CPU speed increases to 2200MHz. Now a divider of 6 gives 367MHz, rule #2 is now violated. The computer knows this and increases the divider to 7, giving 314MHz, satisfying all rules.
It can be complicated I know, but if you understand the 3 rules you should be able to figure out what the divider will be for any combination of CPU multiplier and memory setting without using the charts. But until then, the charts can be a great quick reference.
I sense a lot of answers in your reply, but i have to read it more than 1 times haha, ok hmm so basically the divider for 667, 800 etc., are determine by what my CPU Speed are?
Example:
DDR2 800, Multiplier 16x, HTT 200MHz
divider 5 = 640MHz (violation)
divider 6 = 533MHz (violation)
divider 7 = 457MHz (violation)
divider 8 = 400MHz (satisfied)
So that means the divider is 8 for DDR2 800, Multiplier 16x, HTT 200MHz. (right?)
If memory cannot exceed 400MHz at HTT 200MHz for DDR2 800
What MHz the memory cannot exceed IF the HTT is 210 for DDR2 800
If memory cannot exceed 333MHz at HTT 200MHz for DDR2 667
What MHz the memory cannot exceed IF the HTT is 210 for DDR2 667
Thanks a lot! I understand more
Discussion Starter · #12 ·
Not exactly. The variables in determining the divider are a) CPU multiplier and b) memory setting (i.e. DDR2 800, DDR2 667, etc). So for any given memory setting, the only other thing you need to know is the CPU multiplier. Total CPU speed depends on the CPU multiplier AND the HTT, but your divider stays the same no matter what HTT you use. The divider only depends on the memory setting and CPU multiplier.
Example:
There you go, you're getting it! As the HTT is increased, the divider will stay the same. So the memory will start to overclock as you increase the HTT.
You can think of it like this:
Memory is rated to run at certain speeds, timings, and voltages at a stock HTT of 200MHz. For DDR2 800, that speed is 400MHz. The manufacturers make no guarantee that the memory will work at faster speeds, so the computer is setup to choose a divider that won't allow the speed to exceed 400MHz in a traditional non-overclocked system with the HTT equal to 200MHz. That's why when figuring out the divider you assume the HTT is 200MHz. But once the divider is chosen, it stays the same unless you change the memory setting or CPU multiplier. So as the HTT increases, so does the memory's speed. You can take it well beyond 400MHz if you have good memory.
Cool! So how much will the memory get increase if i increase HTT to 210, if HTT 200 results in 400MHz for memory?
How much can we push the memory? I'm using Corsair TWIN2X2048x6400 kit, how far to increase that the result will be safe and sweet.
By the way, since i don't know how to overclock the professional way, i only know how to do it by adjusting the multiplier like everyone said especially Tom's Hardware, so i wanna learn to use the multiplier and HTT to overclock so that i can overclock the memory as well.
I can't increase the HTT somehow, i've tried few times, there was one time only a mere 210 and leaving the multiplier on it's default 13x, the PC won't boot up, did i miss something? I noticed cool and quiet is disabled, what else should i check for?
Thanks durch
Discussion Starter · #14 ·
Ok, so the first thing you do is figure out what divider you're using based on the two factors a) CPU multiplier and b) memory setting. Once you know the divider (and know that the divider won't change unless you change the memory setting or CPU multiplier), then you can calculate the memory's speed using the equation in my original post:
memory speed = (total CPU speed)/divider
So as the HTT is increased to overclock the CPU, the memory will also start to overclock.
You asked how far you can push your memory, and that's something you can only find out through experimentation. If the memory becomes unstable, the first thing you should do is loosen the timings from 4-4-4-12 to 5-5-5-15. You'll probably need to do this somewhere between 425MHz (850 effective) and 475MHz (950 effective), but that's just an estimate, no way to know for sure where your RAM will become unstable. If you hit instability with 5-5-5-15 timings, then consider giving your memory a bump in voltage, nothing more than 0.1 volts though to be safe. After that, your options are pretty limited.
I'm working on an overclocking guide for AM2/DDR2 systems, I'll let you know when I've completed it. But until then, there's some overclocking guides here for socket 939 systems that might be of some help (although they use DDR memory so many of the steps aren't relevant to DDR2 and socket AM2). Check out the stickies in the AMD General section. You can also browse google for some good guides. Goodluck!
Oh thanks, i think that guide will help me understand more, but you've did a good job so far, i think i finally understand, i just need to get my hands dirty and experience it.
So far i did some simple test
I tried Multiplier 13x (default) and HTT 200MHz (default) = 2600MHz
Divider for DDR2 800 is 7 (371) so divider will stay the same (7) heh
So now i increase the HTT to 230MHz, 13x230=2990MHz
2990/7=427MHz
I used CPU-Z and checked the memory and got 427.3MHz
This....means.....i'm successful eh?
The hard part is to overclock to the CPU speed i want sometimes i can't get the RAM speed i want, it maybe too much or too little.
To use multiplier 12x for example, to get the desired speed of 3000MHz, i increase HTT to 250MHz and since divider is 6, the results is 500MHz, that's a bit too much for me i think :x
I guess multiplier 10 and 12 are got memories above DDR2 800, so far i find 13x has some sweet spots, like 13x240MHz = RAM 445MHz, 13x250MHz = RAM 465MHz.
But i think i will try 13x240, since my MOBO won't allow me to increase CPU voltage over 1.350V so i can't go above 3100MHz i think.
Thanks. Lookin forward to the AM2/DDR2 guide from you.
okay i am having such a delema trying to figure out an over clock...i have been racking my brain over how to write an equation of the two different things...the memory divide that cannot exceed a max speed and the correct divide value dependent on the divide and dependent on the cpu multiple...whooowwww i hope i didn't try and confuse anybody...
okay i have a x2 4600+ @200x12(2400mhz) 1.35volts....
i also have 4gb 2x twin2x2048-6400c4...which is proving very difficult to overclock my cpu with 4 stick population!!!!
:swearing:
on a ga-m59sli-s5 (which has problems going above 312mhz fsb!!!
i have tried numerous different approaches to ocing this chip on this board in order to not get the newer meaning of 1:1 ratio which i have found to me is unreachable!!!!
i am know trying to get 3.2ghz just because i think it would be cool and because my motherboard i think can handle the overclock...but the memory is as i stated earlier a pain in the arsseee to keep undercontrol and stable in an overclock...
the reason why i am trying for 3.2ghz is because at the time i was thinking to keep memory under 800mhz (or 400) but i forgot that to divide by 8 i would have to lower divide to 533 which would only allow for 267mhz and then i would have to rethink the whole idea...
can someone please enlighten me on an easier approach than what i am trying
because i cannot seem to keep the speed of the processor under the limit of the memory...if i am wrong please tell me so i don't go around thinking the impossible with this oc
OK i have just one question If you have DDR2 667 and you now it will run over 800 can you just set it to DDR2 800 in the bios? so far i know it runs stable at 800 just haven't tried to go any higher yet. Edit ok i passed the 900 mark on my mem. running 5-5-5-15-20 2T at 2.0v. and i can keep going but i have just one problem I guess i ended up with a bad board b/c my HTT clock wont go over 280 don't know why, but in Ntune i got it to go all the way up to 340. Ive tried to drop the HT Multy down to 4 but steal no good. So i sad what the heck now I'm running at DDR2 800 speeds with a Htt set at 200.9 so now i can push my ram even farther maybe even get to 1000 at 2.1v who knows it seams to be a really good batch of memory. My HT will run stable at 1400mhz after that it down for the count.
I want a cookie
- my MSI K9A2 CF mobo has a CPU:memory ratio option in the BIOS (AMI BIOS A7388AMS rev 1.6).
It is AM2 and uses DDR2.
Which is why this and other posts have been confusing me with all the talk about dividers with options I can't seem to access. Where do I learn more about overclocking with this seemingly archaic usage?
Discussion Starter · #19 ·
You know this is a question I've had for awhile too but never bought DDR2 667 to experiment with. It sounds like you were able to set the DDR2 667 to DDR2 800 in the BIOS without overclocking the reference clock (HTT), is this correct? I'm definitely interested in knowing.
As for your reference clock (HTT) not going over 280, try giving the motherboard voltage a few bumps. Also, make sure it's not your CPU that's holding you back. When testing for the max reference clock (HTT) you want to make sure neither the CPU or memory goes over stock speeds.
Originally Posted by karossii View Post
I want a cookie
<-- starts baking
But you cheated, you're using a 790 board that came out after I wrote this lol. I haven't used an AMD system in several months now, interesting to see that at least some boards are going back to the 939 days of ratio's. Because the divider depends on both that ratio and the CPU multiplier, the ratio you choose will only be correct if you're running an even CPU multiplier. It's going to make it a little hard to figure out what your memory speed actually is, but that's what CPU-Z is for. I'm not sure what ratios your board gives, but here's some general correlations for an even CPU multiplier and a stock (200MHz) reference clock:
1:1 DDR2 400
3:4 DDR2 533
3:5 DDR2 667
1:2 DDR2 800
2:5 DDR2 1000
3:8 DDR2 1066
a friend of mine is running an X2 6000+ @ stock with 2 2GB DDR 2 800mhz sticks of ram.
based on ur article i wud believe that the divider would b 8, and thus have a memory speed of 3000/8 = 375 mhz per channel or 750 mhz. this is confirmed by the ddr2 ram divider charts which u linked us to.
however his frequency monitor (i believe he is using ntune) is saying that his frequeny is 804 mhz. what would cause this, considering he has done no overclocking?
he is using an asus m2n32-sli vista edition
1 - 20 of 88 Posts
