DDR3 2200(O.C)/1333 Question
29127 Views 12 Replies 9 Participants Last post by  Razultull
Does this mean that the mobo can use DDR3 2200 ram or does it mean i have to overclock the 1333 ram to 2200?
1 - 13 of 13 Posts
it will support that high with memory multis at x fsb
so id have to overclock the 1333 ram?
it means the 1333 is the standard but it can take higher but you have to manually set the speeds for the ram.
okay, now this may sound dumb, but i have lil exp with desktops, but, i assume id set the speeds to 2200 in BIOS, now, would the PC need ram to boot into BIOS? Meaning id need 1333 ram to do this first?
short answer no, but you may have depending on that fsb/qpi you will be running.
You won't have to overclock anything, but the board may set the ram at 1333mhz speed instead of it's full speed.
It means the mobo can support DDR3 frequencies upto 2200MHz.
You can either overclock slower RAM sticks or use ones that run at a max speed of 2200.
If you buy a stick that can run at higher speed, mobo will only transfer data at 2200.
If you buy a slower stick, it will run at that frequency.
No, you can almost certainly set higher, with the right BCLK and memory multiplier. It's just that higher speeds aren't guaranteed to work (though they may), no matter the quality of the other components.
I am still confused with the answers for this so hopefully somebody else replies. If I buy the corsair dominator 1600, and my board the Gigabyte X58A UD9 has support for DDR3 2200+/1333/1066/800 MHz memory modules do I just go into the bios on startup? What do I have to change in the bios?
Alright dude,
When it says a board supports up to 2200MHz RAM, it says it can support that CYCLING FREQUENCY. (Since Hertz is the unit for frequency)
Now.
You may overclock your RAM, but you can only overclock it so much.
The other alternative is to BUY faster RAM, this can get very expensive.
For example,
RAM @ 2000MHz speed
RAM @ 1600MHz
As you can see they cost differently, and if you look closer, you can see something like 8-8-8-24, which are the latencies, which can also push your price way up.
So you see, people can indeed overclock RAM, but many choose to buy very fast RAM and under clock it slightly, preserving the latency, of course thats a preference.
If you want to learn a little about RAM i suggest you go to Anandtech they have a very useful guide to understanding RAM.
Reactions: 2
So if your board only supports 1600 but you use 2000, it will see it as 1600 but will over clock better?
I'm not sure, but something along those lines, or it may not recognize it at all....
Either way, the more the overclock, the easier it becomes when you have faster RAM.
Ergo,
2000MHz RAM is easier (you may achieve stability faster) than a 1333Mhz RAM.
As is said earlier, your RAM gets a little under clocked when you overclock off the bat. Of course you may tune it later so your RAM can overclock too.
Most of todays boards support up to 2000MHz RAM so youre fine, High end boards like the Rampage III Extreme supports up to 2200.
1 - 13 of 13 Posts
