ddr3 duel channel running on i7 mobo
423 Views 9 Replies 8 Participants Last post by  Riskitall84
can i do that?
1 - 10 of 10 Posts
Yes, but you lose performance. How much performance? some-what noticeable.
Yep, not an issue at all.
it is ocz platinum 1.9v you sure?
what CPUs are supposed to run the low voltage 1.65v ram?
1.9v will probably not work. if it was low voltage ram it would though.
but ill try to run it on 1.65 volt and the normal 1600mhz it will be 800 and it is only temproraly max 2 weeks.
it will run in dual channel mode, if you can find an extra stick, then slap it in and run tri
I ran my OCZ 1.9 Volt PC12800 Dual channel kit on my i7 whilst my other ram was on RMA - No issues. Had to loosen the timings a bit to run 1600 at 1.65 Volts that was all.
1 - 10 of 10 Posts
