Source
Interesting read, thought you guys might appreciate itExtreme overclockers know about the importance of the right memory kit and the correct memory settings. Apart from CPU and GPU, the memory can have a huge impact on benchmark results. Being part of several online communities, I read a lot of stuff every day such as "just buy the cheapest memory kit, because more than 1600 MHz and 1,50 Volt won't work anyway with your CPU" which is simply not true in several ways. To help you guys find the correct memory kit, I will enlighten some myths in this post.
