1 - 2 of 2 Posts
I was putting together a computer for a friend, and everything was working fine the first time I plugged it in. Then I took it all apart again because I decided to screw down the motherboard differently. Then when i reconnected everything, the CPU fan wasn't working. I never unplugged it during the whole process. I know its the slot, because the fan works when plugged into the northbridge slot. What the hell can I do? Is it safe to just plug it into the nb slot? The motherboard is a MSI KT880 Delta model ms7047 version 1. Help?
its safe to put it in your nb slot if its 12v....as long as your fan runs 100% and the temps are allright (under load)
1 - 2 of 2 Posts
