Hi
If you need a beast this is it
Its so big it cools your ram
http://www.newegg.com/Product/Produc...82E16835103026
Model
Brand COOLER MASTER
Series GeminII
Model RR-CCH-ANU2-GP
Spec
Type Heatsinks only
Compatibility Socket AM2 / 754 / 939 / 940 / LGA775
Color 2-Tone
Heatsink Material Copper Base / 6 Heatpipes / Aluminum Fin
Physical Spec
Heatsink Dimensions 175.0 x 124.6 x 81.5mm
Model
Brand COOLER MASTER
Series GeminII
Spec
Type Heatsinks only
Color 2-Tone
Physical Spec
When I first opened the packaging, I was really blown away by this monster. Although the cooler is enormous, its not as heavy as some might expect, which I attribute to the use of thin aluminum fins. Assembly and installation took about 15 minutes (including motherboard removal). The performance was very good, and for those using motherboards with heat pipe cooling (think Gigabyte GA-965P-DQ6, or just about any ASUS motherboard), this might be the perfect cooling solution. During our testing the GeminII was neck and neck with the Thermaltake Big Typhoon, but we saw something else that really impressed us; a noticeable drop in temperature for our chipset and other components. The ability to slide the fans horizontally on the cooler makes installation a bit easier. |
