1 - 3 of 3 Posts
if you are looking to buy it off of ebay then I wouldnt get that. cpu is about 150 and I wouldnt spend more than 100 for the rest (mid-range stuff, not high end gear) Need a better PSU and nice graphics card.
You are better off building it yourself if you can. Otherwise you might want to consider that, but its sold as is
BTW what are you planning on using your new system for? gaming should be amd, not intel.
1 - 3 of 3 Posts
