I am not familiar with those exact models, but anything will fit into anything else with a little (or a lot) of modding
. Anyway, most mice wheels are just a circular rubber thingy that is rotating on an axle type thing that gets the actual data, so removing one shouldn't bee too much of a problem.
If you have both mice on hand, take some measurements of the scroll wheels, and if they are the same size, it should go over without a hitch.
Of course, it depends on the Deathadder model too. The newest Deathadder has a different scrollwheel to the older ones, so just keep that in mind.
