The way I look at it is actually kinda simple.
I have 5 cards in my Case:
TV Tuner
Sound Card
NIC
RAID Card
Now the Sound card & TV tuner do not creat alot of heat, but my NIC & RAID card do. They actually require heatsinks. So I have my side fan blowing in on them. It creates possive pressure in my case causing less dust to get in, but possible a slightly higher case temp.
On the flip side though:
While running 2 GPU's with heatsinks that just dump heat in the case, I went for negative pressure as it caused my internal case temp, GPU, CPU, & NB temps to all drop.
Though, I first did this by setting it up so my side fan was an intake, I later modded the case so it had exhuast up top.
Either way I found is fine, but it's usually worth experimenting to see which helps you the best.
TV Tuner
Sound Card
NIC
RAID Card
