1 - 4 of 4 Posts
Hi guys,
I was told if i start my own threat i will get better results.
So if i currently have a 1680x1020 monitor (MAY upgrade to a 1920 res. monitor in a yr or 2)
and play mainly starcraft 2, dota 2 (currently betaing), and diablo 3
how does my build look?
Case: Corsair 600T
CPU : i5 3570K 3.40 GHz (OC to 4.0ghz approx)
Mobo : ASUS P8Z77-V LX (not planning to SLI)
Mem: 8GB DDR3 1600MHz Corsair Vengeance
SSD: Intel 520 120gb
HD: 1 TB regular harddrive
random DVD RW
Radeon HD 7850 2GB
Corsair A50 120mm Fan heatsink
600w Corsair GS
1. My question is, 7850 will be ok with the 600w, but if i were to go 560 TI OC, will it exceeed 600w?
2. Also if i were to do replace my 7850 with a better card 2 yrs down the road, will 600w cutting it?
3. How easy is it to swap power supply?
thanks guys!
Thanks my friend!
To clarify (i'm paranoid), we are talking about a non OC 7850 vs a OC'ed 560 TI and 7850 still wins?
and if i still decide to go with 7850, how much of the 600w psu would be left (please take into consideration the OC to 4.0 ghz approx) because i want to see if 600w is enough.
Originally Posted by darbebo View Post
Thanks my friend!
You will be fine with either of the mentioned GPU's above.
The GTX 480 will blow the other 2 GPU's out of the water, and costs less..
You can OC the 480 to 800mhz with no added voltages, this will bring you GTX 580 performance for a crap load less money
1 - 4 of 4 Posts
