1 - 8 of 8 Posts
Hey guys, i wana put a theme on my comp. But i can't get styleXP because the TGT site isn't working, is there anywere else i can get it from, or gdo you now any other theme apps? thanks Iced
stardock.com<br><br>
edit: I feel your signature completely, *****
Reactions: IcedEarth
crystalXP.net
Discussion Starter #4
<div>Originally Posted by <strong>jcbzhnsr1</strong></div>
<div style="font-style:italic;">stardock.com<br><br>
edit: I feel your signature completely, *****</div>
</td>
</tr></table></div>
Lol!!<br><br>
Thanks guys will check em out.
uxtheme patch
Trust me... Don't use any of the suggested ones. No offense to the 'suggesters' but you can use a LOT less system resources by using a modified .dll that integrates itself into Windows XP:<br><br><a href="http://www.neowin.net/forum/index.php?showtopic=140707" target="_blank">Neowin UXTheme Multi-Patcher v4.0</a><br><br>
once you've installed it, put your .theme files in C:\\windows\<br>
esources\hemes, and your .msstyles in C:\\windows\<br>
esources\hemes\\<name of style>.<br><br>
To use/apply the theme, go to your Display properties on the desktop (Right Click > Properties), and the themes should be there. However only .msstyle and .theme files work. To get those types of themes, check this website out:<br><br><a href="http://browse.deviantart.com/customization/skins/windows/visualstyle/?order=9&alltime=yes" target="_blank">http://browse.deviantart.com/customi...=9&alltime=yes</a><br><br>
It will be just like StyleXP in that you use the same themes you would if you had it.
the link to the patch claims to be non-exsistent, any other links to it?
<div style="font-style:italic;">the link to the patch claims to be non-exsistent, any other links to it?</div>
</td>
</tr></table></div>
Yea I fixed the link.
1 - 8 of 8 Posts
