Setup:
2 speakers + 1 separate sub woofer. The 2 speakers are normal PC speakers and the sub has RCA cables plugged into the center ports, then out to a RCA to 3.5 mm converter jack, then into the PC via 3.5mm. The speakers are in the green and the woofer in the black port.
I also use headphones when I game.
Sound cards:
Mobo (sig rig) onboard and Creative SB Audigy SE/LS/Value SB0570.
I've been using just the Audigy SE since Ive had this PC. I tried reading the Audigy manual, but it wont open right.
Also, I've had my settings on the Audigy as this: 4/4.1 setup w/ CMSS-3D enabled. Just now I found out why 2/2.1 was sound odd, CMSS-3D was enables, however the sub does not output any in either port. So should I do 2/2.1 or stay at 4/4.1 for general/media use or other?
What about gaming? I use my HD 280s when I game since they're my only pair, so should I enable CMSS-3D and 7.1, for virtual surround sound?
Audio output quality is set to: 96Hz sample rate and 24 bit depth.
As a side note, I tried using the orange port for the sub, but I do not get little to no bass at all, but it works great in the black port.
Another question, it says there is a headphone detection option, how does that work...? Is there a different port for my headphones and is it worth enabling?
Also, is this a real program for my sound card? It was on creatives website;
Thanks a bunch! I will be checking this frequently, so fee free to ask questions!
Sound cards:
