1 - 2 of 2 Posts
Deepcool Gammaxx S40 CPU Cooler
Description:
Deepcool Gammaxx S40 CPU Cooler:
Support Intel LGA2011/1366/1156/1155/775 and AMD FM2/FM1/AM3+/AM3/AM2+/AM2.
Ф120x25mm fan with PWM function offers a perfect balance between airflow and noise.
Double Airflow Channel(D.A.C.) technology allows more cold air to cool the surrounding components, such as MOS.
4 pieces of Ф6mm heatpipes, Core Touch Technology (CTT) gives perfect contact with the CPU surface.
The whole heatsink set is nickel plated for appealing appearance and also for gaming spirits.
For more: http://www.deepcoolglobal.com/Product/GAMMAXXS40/
www.facebook.com/deepcoolglobal
Cheap, compact, but effective enough for moderate overclocking
review by foxtrot814
Summary: Deepcool Gammaxx S40 offers adequate performance for moderate overclocking for just under $30. It is compact, easy to install and not too noisy. Due to its 143 mm height it should fit narrow Micro-ATX cases.
ProsCons
Cheap, compact, supports all sockets, VERY simple installation, good price/performance ratioNo extra thermal compound included, high temperature difference between low/high speeds
Ratings
Overall4
1 - 2 of 2 Posts
