1 - 7 of 7 Posts
don't think it could hurt
It will help, not hurt. I wouldn't bother unless you're getting stuttering or noticeably long load times though. Just let them defrag when you do a normal full-disc defrag.
But that's the thing your not supposed to defrag an SSD. I thought this might have been different though.
defragmentation on a SSD is pointless generally.
if you somehow got your filesystem to have 50000 peices per file it would be worth doing a "quick defrag" just to reduce the pieces a little, but by the time it got that bad would be a really really old install that was like 5 yrs old and had a full drive for years... so at that stage you could just reinstall anyway
Defragmentation involves rearranging the location of the files on your mechanical hard drive. Because you don't have any moving parts on a SSD, the access times are the same across the SSD, defragmenting a solid state drive is useless. It may hurt too, because of the extraneous read/writes.
1 - 7 of 7 Posts
