1 - 6 of 6 Posts
Hey,
Just wondering if a dehumidifier would be worth having inside a relatively sealed case, just for extra safety? Or even if it could replace the need to seal everything against moisture to a certain extent.
thanks.
Originally Posted by Bitemarks and bloodstains View Post
i think you need a little moisture as too little can cause static to build up
really? I would've thought the PSU would remove any static, since it's connected to the mobo and case and is connected to an earthed socket.
Um I doubt that you would have a problem but still with your cascade your still going to get condensation unless you have a perfect 0% humidity. I wouldnt worry about it that much unless you live somewhere that is really humid like generally above 90% maybe.
As far as the static stuff I dont know about that. I lived in colorado where it can get to very little if any humidity at times and I never saw any issues with any electroncis that were grounded properly.
1 - 6 of 6 Posts
