1 - 13 of 13 Posts
go to counterscripts.com they have that script there or fpsbanana.com also theres a funny script that lets you spin around like a hacker too.
Originally Posted by TnB= Gir View Post
You don't need it. It's only for showing off.
I've played CAL for 3 seasons and have never used a script, I think it's ******ed.
Lol, if your name stands for titties and beer like the team, I think I scrimmed you guys a few.
I quit competitive play, i've played for 3 years and still can't beat cal main teams.
Don't use scripts in CAL.
Last i heard they are not allowed. Especially the jump scripts, etc.
Anyways, its just a fun thing otherwise.
You can try FPSBanana.com for scripts. Great community, used to be an active over there.
Not on that team anymore. I wish everyday that I would've registered on here as just Gir.
First off, it would be better with a glock, because you could buy more of them before you ran out of money
Second, you would have to make it start off by switching to your 2nd slot (pistol's slot), then drop your current one, buy a glock. Most people bind it to the mousewheel so that they can just scroll that. And just make sure you're aiming a little bit upwards when you're doing it, and you'll throw the gun up into the air and it will make a "glock fountain" lol
Here's one:
http://www.fpsbanana.com/scripting/3660
Here's another:
http://www.fpsbanana.com/scripting/1925
Originally Posted by exileschild
Perfect, thats what I was looking for. thx
+rep to all helpful posts.
Edit: NO!! It's a script.. I'll use it on my ringer acct.
Well, yeah it's a script... that's how you have to do it...
I mean, I believe you can do it with just a one-line key bind, but it would be pretty long, basically a script. Does it matter, anyways?
I mean, you could say like bind mwheelup "slot2; drop; buy glock" and then that would switch to slot2, drop the pistol there, then buy a glock every time you scrolled the mouse wheel up, but I'm sure you'd probably need some wait commands somewhere in there, I'd have to fiddle with it to figure it out. But you might not, just try that, it may work... dunno.
1 - 13 of 13 Posts
