1 - 13 of 13 Posts
Hi guys!
I have been reading this forum a lot lately. But today i think i messed up really hard.
Yesterday i attempted to delid 2 x5670 for my mac pro 4.1, yes it use delidded processors so it´s a must.
I thought it went well, with a few scratches but well enought, until i have just found that i desoldered one of the resistors or condenser on the top and i can´t find it
I will really appreciate some help, to find the value of the component, i have soldered SMD components before, but i don´t really know how to guest the value and the tipe of this semiconductor.
And i don´t want to spend another 200 euros on other x5670.
Discussion Starter #5
There isn´t any hope really?
he scratches seems not deeper, in the photo seems a lot worse that what they are, just one is touching a big pcb track.
I just need to know the value of the condenser or resistor
Not New to Overclock.net
I don't mean to come off rude, but your CPU is quite dead. And you won't be able to solder the replacement back in unless you can get access to a lab, and that will most likely set you back nearly as much as a new chip.
Delidding should not be done by just anyone, and you have to face the risks.
This PCB has many layers and by nicking them in such a way is very likely to cause traces to touch, which may damage your other components, too.
Bottom line: you've literally wrecked the CPU. It looks like you delidded it with glasspaper, facing down...
Edit: For the love of God, you can see bare copper there. What did you even think you were doing?!
Please, do not get near another CPU with a razorblade in your hands. Not even a vice.
You've probably broken a lot of traces with all those scratches. I've seen people come out with dead chips with 99% less scratches than that. The missing component is the least of your concerns.
This is why the vice method is superior.
Move on, you've learned your lesson, buy a new chip.
pass the lortabs
Terrible lesson to learn.
Rest in pepperonis, lil 5670.
Overclocking is my game.
Did you even try it? A broken resistor isn't a big deal normally and the scratch looks pretty deep but it may still work.
I would literally eat my shoes if that CPU still works.
1 - 13 of 13 Posts
