Originally Posted by
Euskafreez
Good stuff. I was actually kind of surprised by how much and how hard the junk was between the heatsink and the die! I used the iron method not so long ago on a spare i7-920 I hand. Not too much of a job if done properly. Only difference -the heat coming out of the bad boy of an iron I used. I suppose it was enough to melt this junk. A wipe with a clean rag did the job. But in worst case scenario I'll play with the razorblade
I think the iron method is a great idea, I couldn't get it to work for me though and had to go with the torch method. My iron wouldn't get hot enough, I left it on for a little over a minute and couldn't feel like I was making any headway. The torch took about 30 seconds and the IHS popped right off, with the proper set up I think either method can be viable.
Yeah, don't be afraid to scrape the solder off the die with a razor, just keep a low angle and be slow and careful. Try not to hit and damage the caps on the PCB, when you get through the solder you can feel the difference, they die is hard and smooth just like glass. You will know when you've gotten down to it.
