1 - 3 of 3 Posts
hi i reinstalled windows and now i need drivers but i dont know what specific drivers i need? i want to use the internet but the Lan port doesnt work well here is the list which one do i need? <br />
<br />
<a href="http://support.dell.com/support/downloads/devices.aspx?c=us&cs=04&l=en&s=bsd&SystemID=LAT_PNT_PM_D600&os=WW1&osl=EN" target="_blank">http://support.dell.com/support/down...&os=WW1&osl=EN</a><br />
<br />
its a Dell latitude 600
Administrator
<u><b>When Reinstalling Windows you will always need the following most important drivers : </b></u><br />
<br />
1. Chipset Drivers : <a href="http://support.dell.com/support/downloads/download.aspx?c=us&cs=04&l=en&s=bsd&releaseid=R114079&SystemID=LAT_PNT_PM_D600&os=WW1&osl=en&deviceid=1134&devlib=0&typecnt=1&vercnt=3&formatcnt=1&libid=27&fileid=149851" target="_blank">http://support.dell.com/support/down...&fileid=149851</a> <br />
<br />
2. IDE/EIDE Controllers : <a href="http://support.dell.com/support/downloads/devices.aspx?c=us&cs=04&l=en&s=bsd&SystemID=LAT_PNT_PM_D600&os=WW1&osl=EN#" target="_blank">http://support.dell.com/support/down...os=WW1&osl=EN#</a> <br />
<br />
( You need to get the most appropriate ones for your hard drives/Hardware. ) <br />
<br />
3. Display Drivers: <a href="http://support.dell.com/support/downloads/devices.aspx?c=us&cs=04&l=en&s=bsd&SystemID=LAT_PNT_PM_D600&os=WW1&osl=EN#" target="_blank">http://support.dell.com/support/down...os=WW1&osl=EN#</a> <br />
<br />
( As with Above you will have to get the correct version for your hardware. ) <br />
<br />
These are the most important drivers for basic setup and Readines. <br />
<br />
However for your Lan drivers so i can help more can you tell me the make of them at all as they could be the Realtek lan. <br />
<br />
Check out Realtek Drivers here : <a href="http://www.realtek.com.tw/downloads/" target="_blank">http://www.realtek.com.tw/downloads/</a><br />
<br />
Also check out my Windows Faqs in my sig .
this is what it says:<br />
<br />
broadcom corp BCM5705M NetExtreme Gigabit Ethernet<br />
<br />
Intel Corp Pro/Wireless LAN 2100 3B Mini PCI adapter
1 - 3 of 3 Posts
