1 - 20 of 28 Posts
Starting to become a BOFH
Try a paper clip in the hole?
Originally Posted by anthony224847 View Post
Really?
Do you know where the hole would be located?
It's close to the eject button. It's tiny and easily overlooked if one is not looking for it.
Someone in the Linux forum should be able to help.
Yeah, he's got a slot loading tray. :\ I don't know how to get the disc out of those.
I'm confused. Does the laptop have a casette that ejects on which you mount the disc, or is it a slot where you slide the disk in, and an internal mechanism grabs the disc? edit--nvm, I understand it's the latter now
I hate to ask, but have you tried pressing the eject button on the keyboard? I only ask because keyboards generally function outside of windows, even some of the "advanced" functions on them. I'd feel bad if I didn't ask this and assumed.
1 - 20 of 28 Posts
