Hello!
Recently I purchased a Qnix QX2710 monitor and even before I placed the order I knew I was going to change the horrible stand. Looked up many different stands and ended up getting a Dell U2414H monitor stand ( http://im.tech-details.com/jpg/monitor/DELL/DELL_U2414H1.jpg), fully adjustable! The only problem was that the height adjustment weight-balancing spring were not supporting the weight of the Qnix. I looked the issue up, but couldn't find how to adjust the tension of springs, only other people asking the same thing. Luckily, the seller sent me the wrong stand initially, than sent the correct one and left me the wrong stand too. So I decided to see if the spring can be adjusted by taking the stand apart. I was able to adjust the spring very easy and I decided to post a little "how to" for people that may find themselves in the same situation.
This applies to most Dell stands that use weight balancing spring for height adjustment. (some use a button to lock the monitor in position)
1. Remove mounting plate, some have 3 screws, some have 4(in my case this was changed with a VESA adapter plate Dell sells)
VESA adapter plate pics
For sale on ebay
2.Remove the plastic coveri Simply pull the plastic cover open, start at the top and continue all the way to the base of the stand
Bend the mid-piece from under the tilt/pivot mounting base. Nice and easy so you don't break it!
5. With the plastic cover out of the way, we have access to the screw that adjusts the tension of the spring
6. If the spring is too soft and the stand cannot hold the weight of the monitor you need to tighten the screw/ adjust clockwise.
If the spring is to strong simply unscrew/ adjust counterclockwise.
Mount everything back when done! Try the spring as you adjust the tension until it "feels" right. You may have to redo if didn't tighten/unscrew enough.
Hopefully this will help some people.
EDIT: With @ENTERPRISE's permission, I updated this post {Thank you!
}! The links I used back in 2015 were dead and I got messages about this, so there you go!
For sale on ebay
