Hey guys!
I've been hunting for a new screen for a while now and have filtered the list down to these two monitors:
Dell UltraSharp U2913WM
Tech Specs
LG Electronics 29UC97C-B
Tech Specs
I'm currently using the Dell Ultrasharp U2212HM and love the sharpness and color output of it, but I want to switch to a 21:9 screen. The resolution of 2560x1080 is sufficient for me as I prefer downscaling than having a larger screen for more pixels (hate jaggies).
The main question for me is: How does the LG match up in picture quality to the Dell? It is the newer model and has a curved screen which suits me better, but only if the loss in image quality is either none or not noticeable.
Does anyone have experiences with both displays?
Tech Specs
Display
Diagonal Viewing Size:
73.02 cm
29 inches (28.75 inch wide viewable image size)
Active Display Area (H x W):
672.77 x 283.82 mm
26.49" x 11.17"
Optimal resolution:
2560 x 1080 at 60 Hz
Aspect ratio:
Ultra widescreen (21:9)
Pixel pitch:
0.09 (H) mm x 0.26 (V) mm
Brightness:
300 cd/m² (typical), 50 cd/m² (minimum)
Adjustability:
Height-Adjustable stand, tilt, swivel and built in cable-management, capacitive touch OSD controls
Color Support:
Color Gamut (typical): sRGB >99%, 82% (CIE 1976)4
Color Depth: 16.7 million colors
Contrast Ratio:
1000 to 1 (typical), Dynamic Contrast Ratio: 2 Million:1 (Max)
Viewing Angle:
178° vertical / 178° horizontal
Response Time:
8ms (grey to grey)
Panel type, surface:
In-plane switching, anti-glare with hard coat 3H
Backlight Technology:
LED
Display Type:
Widescreen Flat Panel Display
Flat Panel Mount Interface:
VESA
Display Screen Coating:
Antiglare with hard-coating 3H
Audio Output:
DC power connector for optional Dell Soundbar
Stand
Height adjustable stand, tilt, swivel and built-in cable management
Connectivity
1 Dual Link Digital Visual Interface connectors (DVI-D) with HDCP
1 DisplayPort 1.2 (DP)
1 Mini DisplayPort 1.2 (mDP)
1 High Definition Multimedia Interface (HDMI)
1 Video Graphics Array (VGA)
1 USB 3.0 upstream port
4 USB 3.0 downstream ports
1 DisplayPort out
1 Audio out
DC power connector for Dell Soundbar (AX510)
73.02 cm
672.77 x 283.82 mm
26.49" x 11.17"
Optimal resolution:
Aspect ratio:
Pixel pitch:
Brightness:
Adjustability:
Color Support:
Contrast Ratio:
Viewing Angle:
Response Time:
8ms (grey to grey)
LED
Display Type:
VESA
Audio Output:
Stand
Connectivity
1 DisplayPort out
1 Audio out
Tech Specs
General
Screen size (inches) 29
Panel Type IPS
Aspect Ratio 21:9
Resolution 2560 x 1080
Brightness (cd/m2) 300
Response Time (ms) 5
Response Time_Typ. (ms) 14
Viewing Angle (°) R/L 178 (Typ.), U/D178 (Typ.)
Colour Depth (Num of Colours) 8bits
Pixel Pitch (mm) 0.2826 x 0.2826
Colour Gamut sRGB 99%
Surface Treatment Hard Coating(3H), Anti-glare
Input / Output
HDMI Yes(2EA)
DisplayPort Yes (1)
Headphone Out Yes
Audio
Type 2ch
Built-in Speaker Yes - 2x7W
Features
DDC/CI Yes
HDCP Yes
Plug & Play Yes
Response Time Control Yes
Key Lock Yes
Special Features
Flicker safe Yes
SIX Axis Control Yes
Colour Calibrated Yes
Panel Type IPS
Aspect Ratio 21:9
Input / Output
HDMI Yes(2EA)
DisplayPort Yes (1)
Headphone Out Yes
Audio
Type 2ch
Features
DDC/CI Yes
HDCP Yes
Plug & Play Yes
Key Lock Yes
Special Features
Flicker safe Yes
