dell
1229 Views 14 Replies 5 Participants Last post by  Waffles
is it possible to overclock a video card on a dell?
1 - 15 of 15 Posts
yes. regardless of make or type (dell, hp, laptop, desktop, etc), as long as you know the type of video you have, you can always oc it
ati 9500 pro/9700
how might i do the overclocking?
btw thanks for the initial info
try ATI tool. it's one of the easiest to use
how does one go about getting ati tool or power strip?
edit ******
and do i need additional cooling other than stock fan?
Stock will work but if you want you can put Arctic Silver on the gpu.
k cool. and how about gettin ati tool? how does that work?
You should be fine. OC then check temps on your GPU. To much then lower the core voltage and so on.
www.guru3d.com has both of them. A vantec pci fan wil help a little bit. Keeps my 6600 gt cool.
i clicked find max core and the sucker froze...
click the Show 3d View
increase core and mem by 5 MHz, and set clock... if it doesnt freeze post here.
vpu recover has reset your graphics accelerator as it was no longer responding to graphics driver commands
1 - 15 of 15 Posts
