Yesterday I received my TRUE copper and a delta 120mm 4000rpm fan to go with it, I wasn't planning on using the fan all the time (rated at 50db) just to see what the max overclock I can get but I had a problem running it at all.
After installing the true and the fan I ran p95 to check out the temps at stock clocks but my system failed after about 1 minute (no BSOD p95 just came up with errors) after changing the fan for one of my antec tri cools my system was fine and I have now achieved a decent overclock which is stable. why would a fan do this to my system? and should I RMA it?
