This all started about two weeks ago when I purchased a chiller for experimental purposes. I was scanning ebay/newegg one night for various different types of coolant and brainstorming on how I could come up with some substance a little more exotic than water, or additives I could use to enhance heat exchange. This is when the thought popped into my head that cooling a PC with liquid metal may very well be a viable and feasible option. And something I might actually be able to pull off, given enough time and research. One of my side topics of interest are nuclear reactors, so that was what prompted me in the first place, as some nuclear reactors are actually cooled by liquid metal and it is extremely effective, and known as the "ultimate" coolant. I want to get a few things straight so you guys don't think I've gone off the deep end:
1) This is a long term project - It will likely take at least 6 months to a year to design and build and impliment what I am envisioning.
2) This is not practical in any sense of the word - I find it very intriguing, however, and I have a very curious mind, so yes, while early on it will be experimental, I do eventually hope to come up with a liquid metal cooling "solution" that perhaps could be developed into a real product for overclocking enthusiasts.
3) This is not going to be cheap. Gallium costs about $100 for a 1/2 cup, to put things in perspective.
4) This is totally experimental for the moment, but I think I can make it work, and if I do I will try to come up with a kit or formula that other hardcore OC people can buy and implement themselves.
5) This will be a great covid project as I dont see us coming out of this pandemic anytime soon lol
I first came across Mercury, obviously one of only a few metals that is a liquid at room temperature. But this is nasty stuff, and the vapors alone are enough to keep me away, far away. Then of course there is Gallium, which I think with the right tweaking will make the most effective "liquid metal coolant" for this project. Gallium has some very cool properties and has a melting point of 85*F, which is obviously to high to be used practically in this scenario. It is also very corrosive to aluminum so all the parts used in this liquid metal loop will have to be compatible with a gallium based alloy.
Galinstan - Wikipedia
So I did a little more research and came across a very interesting alloy known as Galinstan, mixture of gallium and indium (and a pinch of tin) which has a melting point of -19*C (-2*F). I need to do more research but if I really want to take advantage of liquid metal as a high performance coolant, I need to involve a chiller in this conversation. Because in a normal loop, with standard radiators you might only see 5-10% increase in thermal dissipation properties of LM vs standard water loop. If you can get the heat out of the liquid metal very quickly, you get more bang for your buck, and can further capitalize on it's superior thermal dissipation properties. In other words, my plan is to utilize a chiller and a plate heat exchanger which will interface the liquid metal loop with coolant loop from the chiller at about 33*F. A plate heat exchanger is a very interesting piece of equipment in that it offers a huge amount of surface area verses a standard radiator, and a radiator is air to water, whereas the plate heat exchanger is liquid to liquid. So right off the bat, we will be using a highly effective form of heat transfer (liquid to liquid is far more effective than liquid to air). The project requires two independent loops, at least as I see it right now (see graphic below). The liquid metal loop goes through the plate heat exchanger where it gets cooled by the chiller (and the chiller will have it's own independent loop and the two will never touch. For all intensive purposes, a plate heat exchanger is the most effective heat exchanger for use with this kind of idea and will provide well over 20x the surface area of a standard radiator. That's the key here in allowing us to flip conventional thinking about radiators on its head, as I will outline my theory below.
My goal is to run the liquid metal loop with a target goal of maintaining it at about 35*F in that loop. And this is where things start to get interesting. In a conventional loop, the radiators get hot, because you are removing all that heat generated from your CPU/GPU. But then it dawned on me, why would I want hot radiators INSIDE my case? I mean, in the conventional sense, a radiator in a house is designed to heat the house. Do I really want 90*+ radiators in a confined space around very temperature sensitive electronic equipment, especially when I'm overclocking? The rational answer is NO.
What am I getting at? We will use the liquid metal to run the entire loop sub-ambient, so effectively, you will have 35-40* liquid metal flowing through your radiators. In other words, use the radiators to cool your internal case temps, not raise them. Because the liquid to liquid heat exchanger is so much more effective than liquid to air, any decent chiller should be able to maintain the entire loop at sub ambient temperature without to much trouble. There is a very common misconception that running radiators with a chiller is a no no, but actually, when you study it closely, the chiller should have no problem dealing with the temp increase in LM from passing through your radiators. This is effective air conditioning for your system. even if you have two or three large radiators, that's still nowhere near the surface area of the 60 plate heat exchanger I just purchased for use with this project. Yes, there will be condensation and other challenges, but one by one, I will address them.
This LM loop would require a different type of pump (electro-magnetic MDF pumps in particular would be ideal). Taking advantage of the metallic nature of the coolant, the pump pushes the liquid around electromagnetically. Unlike water cooling, the process requires no moving parts, consumes little power, and is silent.
The attraction of liquid metal itself is its excellent conduction of heat, it is 65 times more thermally conductive than water – and 1,600 times better than air cooling.
In short, liquid metal is able to absorb heat more rapidly, and thus cool down chips faster. This property has led to its use as an “ultimate” coolant in some nuclear reactors, which are cooled with liquid sodium or potassium, as well as in the manufacture of high-quality machine components, such as gas turbine blades, where the components are rapidly “cooled” to 660 C with molten aluminum to prevent the formation of defects.
Before you laugh, just know that there are proven liquid metal loops already out there, designed for use with mobile devices all the way up to servers. Nothing holding me back from taking a couple pages out of their playbook for my little project.
This project is in it's intial phases. But I am proceeding with the idea and I will make it happen. Your comments are welcome, both good and bad, just please dont post things like "dont do it" or "it wont work" because I am doing it and WILL make it work.
But your advice is appreciated because I know we have expert opinions out there who can help me or guide me in the right direction to make this whole experiment viable.
Essentially, this layout is similar to what I am envisioning in my head (sump water would be chiller) and liquid-liquid heat exchanger in the center would be the plate heat exchanger)
