1 - 4 of 4 Posts
Greetings, I've got three 24 inch monitors for Eyefinity however I believe I have to replace the current table I have to fit all of them correctly as I'm stuck to only be able to use two right now. I've been looking at Ikea tables and I'm wondering which one of these will fit 3 24 inch monitors and perhaps some speakers on the ends. There's no corner but there's enough straight room available.
78 inch length: http://www.ikea.com/us/en/catalog/products/S69831118
59 inch length: http://www.ikea.com/us/en/catalog/products/S39871399
Which one of these would you recommend, or if there's any other tables with enough room for three 24 inch monitors, please inform me!
Thanks!
I actually use the table top from that desk with my 3 monitor setup. And just buy some legs to go with it... works out pretty well.
Although I did add an adjustable keyboard tray which is pretty awesome! No cables all over the desk
Edit* I just sold the last 24" monitor I had, Im buying 1 big 27" Dell Ultrasharp U2711.. I wasent a big fan of Eyefinity
The 59" desk will not likely fit 3x 24" monitors with speakers on the ends unless you put the monitors in portrait, have the side monitors at a larger angle, or have thin speakers. With 3x 22" monitors, from side to side for me is ~57" but my side monitors are only angled very slightly.
1 - 4 of 4 Posts
