1 - 2 of 2 Posts
Hey everyone,
I'm looking to get rid of my desktop as I haven't used it much recently. The hardware is a bit dated and I'm not sure how much its worth anymore. It would be great if someone could give me an idea of the value if I parted it out.
i7-2600k
Asus P8P67 Deluxe
2x eVGA GTX 580's
2 x 4GB DDR3 RAM
2x Seagate 600 series 480GB SSD's
Blu-ray reader
Silverstone ST-1000 PSU (1000W)
Silverstone TJ07 case
It also has a full WC loop for the GPUs and CPU. Below are the WC parts:
EK HF Supreme CPU block
Koolance VID-NX580 GPU blocks (still have original air cooling parts as well)
Swiftech MCP355 pump (I believe that it has an EK top on it)
Black Ice GTX 480 Radiator
some random plastic reservoir
Compression fittings all around
Thanks!
well the i7 should get you $150ish and the TJ if it's in good condition id put it up for $250. they're pretty scarce cases. Older SSD's are a crap shoot so I wouldn't expect more than $100 for the pair. $125 each for the 580's, $75 for the psu, $50 for lthe mobo, $30 for the ram, and I'd try to do a package deal for the rest of the w/c parts for $150.
hope this gets you started.
1 - 2 of 2 Posts
