1 - 15 of 15 Posts
question:<br>
can i replace the cpu in my lappy with a regular desktop cpu? i have a gateway laptop with a socket 754 turion 64 processor so i was wondering if i could replace that with an athlon 64 socket 754??
No ,you may not. They have different bus ratings and stuff. You need a laptop-specific cpu.
Actually, I THINK you may be able to, but it will run much lower than stock, and the heat will be much more than the mobile chip. You can however buy a new mobile chip <img alt="" class="inlineimg" src="/images/smilies/smile.gif" style="border:0px solid;" title="Smile">
Discussion Starter #4
what other mobile amd chip is there besides the turion? newegg only has two turions-the one i have and one other thats not worth the upgrade
Not worth the trouble
<div>Originally Posted by <strong>BenHagerty</strong></div>
<div style="font-style:italic;">Not worth the trouble</div>
</td>
</tr></table></div>
X2<br><br>
lemme look around for you. What is your current chip?
I don't own a laptop but as far as I know if you remove the IHS on a Athlon64 it should fit, but desktops CPU's use more power and generate more heat. I supose it would work just expect lower battery life.
Discussion Starter #8
<div>Originally Posted by <strong>Krunk_Kracker</strong></div>
<div style="font-style:italic;">X2<br><br>
lemme look around for you. What is your current chip?</div>
</td>
</tr></table></div>
the ml-32 turion 64....and the x2 is crazy priced so thats a no
depends if ur chipset supports it<br><br>
what about the X2? Idk if it supports ur bios tho
Theres a bunch I found on froogle. Apparently theres a x2 Turion you can get, I didn't know that.<br><br><a href="http://froogle.google.com/froogle?q=turion+64&btnG=Search+Froogle" target="_blank">http://froogle.google.com/froogle?q=...Search+Froogle</a>
</td>
</tr></table></div>
The X2 is on a different socket.
<tr>
<div>
Originally Posted by <strong>Namrac</strong>
</div>
<div style="font-style:italic">The X2 is on a different socket.</div>
</td>
</tr>
</table>
</div>I was saying "X2" liike "ditto" <img src="/images/smilies/tongue.gif" border="0" alt="" title="Stick Out Tongue" class="inlineimg" />
The X2 Turions don´t fit in the Turion sockets cause the X2 use DDR2!<br />
<br />
I would look out for an MT-40!
<tr>
<div>
Originally Posted by <strong>The Specialist</strong>
</div>
<div style="font-style:italic">The X2 Turions don´t fit in the Turion sockets cause the X2 use DDR2!<br />
<br />
I would look out for an MT-40!</div>
</td>
</tr>
</table>
</div>Yea, and if you put an A64 in the 754 slot, you will no longer be able to use dual-channel RAM. Not sure if the Turions used dual channel or not.....
1 - 15 of 15 Posts
