Hello OCN, long time lurker first time poster. I'm in the process of building a new rig but I'm still unsure if I've selected the right components. I'm somewhat of a power user but I never stay up to date continuously... I always research and re-train myself every few years when it's time to put together a new PC.
Well, it's been 6 years now and a lot has changed. The publications/websites I used to respect seem to have fallen out of favor (looking at you, MaximumPC) and I'm just not sure where to turn for sound advice. Any help is appreciated!
Anyway, my goal is to build the most powerful SandyBridge gaming rig I can while keeping noise as absolutely quiet as possible -- on air. I'd also like to reach at least 4.5Ghz. My budget is around $1500-$2000. Here are the components I've already purchased:
- Fractal Design Define R3
- G.Skill RipjawsX 8GB DDR3 1600
And here are the components I'm currently planning on purchasing:
- Corsair AX850
- Asus P8P67 Deluxe
- Intel Core i7-2600K
- Corsair H70
- LITE-ON iHBS212 Blu-ray Burner
- XFX Radeon HD 6970
- OCZ Vertex 3 120GB
- WD Caviar Black 2TB
Now for some justifications and concerns:
PSU - I know that 850W is overkill for my components. However, any excess wattage will only help keep heat down, and 850W is decent future-proofing for another build in 3ish years. But is the thing QUIET? And is the AX series really worth it compared to the HX or TX? I figured the superior efficiency would win out in the end thanks to power bill savings. Am I wrong?
Mobo - I just went with what seemed to be the current standard. I'm not a veteran overclocker so I'm not sure if the improved voltage regulation on the Deluxe model is worth it. I figured it was only an extra $50 bucks and every little OCing edge I can get is worth it if I'm striving for a silent machine.
CPU - The i7-2600K seemed like a no-brainer to me. The 2500k may be cheaper, but $330ish is still cheap (right?) for the extra horsepower. Once again I figured that it would be worth it since I'm trying to keep the machine as quiet as possible.
CPU Cooler - The H70 I'm really hesitant on. I've read that it's loud. Noise is the enemy. However, I can't seem to find a definite answer for the best alternative. I read a lot about some Noctura NH-114-something, but when I check newegg there's like 14 different versions (PC hardware is about 20x more confusing than it was 6 years ago, btw). Then when I do more research every review/website seems to contradict the other. So I turn to you, OCN: What freaking heatsink do I want? I want the quietest overclocking demon there is.
Optical - For the bluray burner I simply went with what I read on newegg reviews. I have absolutely no need for a bluray burner, I just want to rip my bluray movies as fast as possible. Based on the reviews this seemed to be the fastest one? Please advise if I'm wrong...
GPU - I selected the 6970 mainly due to history. I just assume that the 6970 is quieter/cooler than the GTX570. Then some people told me I was wrong. Then others said that THEY were wrong. God dammit, who is actually wrong? Does it depend on the brand? Both cards seem to be in the same league when it comes to performance, but what about heat and noise? I game at 1920x1200 on a Dell UltraSharp U2410.
HDD's - I went with the Caviar Black due to a MaximumPC review. Then some other guys told me MaxPC was full of crap and I should be getting a Samsung Spinpoint F3 instead. Who should I listen to? As for the Vertex 3, I mainly went with hype. Everyone seems to think it's going to be amazing so I figured it's the right one to plan on. When it comes to the SSD I simply want the fastest little devil I can get my hands on.
So there you have it. Sorry for the wall of text but I figure it's better to explain myself now and cut down on some of the questions. I appreciate any help and advise you are willing to give. OCN seems to be the place to be these days when it comes to PC performance knowledge. Thank you in advance!
- Corsair AX850
- Asus P8P67 Deluxe
- Corsair H70
