Originally Posted by dbosco002 Ok I just purchased the DFI 925 mobo. Does anyone know if the thermalright XP-120 will fit on that board? I looked on the sit but didn't see it on the list. |
With a customized LGA 775 adapter kit, XP-120 is designed to fit all socket T (LGA775) motherboard. So far, we have not found any board that is not compatible with XP-120. If you've found any, we would appreciate if you could report them to here. |
Originally Posted by archer_456 You shouldn't have a problem with it. Here is a quote from the support page Thermalright website: Here is the adpater |
